1993 Plymouth Voyager fan motor control
1993 PLYMOUTH VOYAGER
14,500 MILES • 6 CYL • 2WD • AUTOMATIC
MARK TAYLOR1
Fan motor only works on high or off. I took the control panel out and replaced with another from the salvage yard. Got the same result. If there is a relay that needs to be replace. Which one and where is it? thanks
Apr 11, 2010 at 1:47 AM
CARADIODOC
  • 34,383 POSTS
Replace the blower resistor assembly. It is bolted to the heater box near the fan motor. There is a thermal fuse in it. If the new assembly burns out in a short time, the fan motor is developing tight bearings and will draw excessive current. You'll need to replace the motor too in that case.
caradiodoc
Apr 12, 2010 at 5:28 PM
