1993 Plymouth Voyager Excessive fuel use
1993 PLYMOUTH VOYAGER
10,300 MILES • 6 CYL • FWD • AUTOMATIC
RHOGO221
On my '93 Grand Voyager I usely get about 360 miles to a tank of gas. For the last four weeks I have only been getting about 250 miles per tank, and it is getting worse. I have run fuel injection cleaner through three tanks of gas with no results. I had the fuel pump and filter changed about 3000 miles ago. I checked the fuel pressure regulator lines for fuel and found no fuel - which is good. A complete tune-up was done about 6000 miles ago. I have noticed also when it sets and idles it kind of revs up and then back down over and over again, and the exhuast smells rich and to high heaven. Any ideas what the problem might be?
Apr 30, 2009 at 12:05 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Yes, thanks for using the site, it sounds like you have a fuel pressure regulator that has failed.
Check this link
lets us know what you find ;-)
Apr 30, 2009 at 1:11 PM
