1993 Plymouth Voyager Cooling Fan
DTAVERNE
  • 1993 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 178,000 MILES
The other day my car overheated and I noticed the fan wasn't running. I removed the fan and found that the motor has something inside (some part of the motor is moving around inside there) that prevents it moving freely. I replaced the fan with one from a salvage yard. They tested it at the yard and it worked. I installed but it won't come on even when I run the engine until it is quite hot--beyond the temp at which the fan would normally come on. Is there a fuse or relay some place that might have gone bad when the old fan became jammed? Thanks.
Friday, July 4th, 2008 AT 12:07 PM
MERLIN2021
  • 17,250 POSTS
The relays for low and high speed operation are on the inner fender, the coolant temp sensor is probably the bad part tho...next to the thermostat.
https://www.2carpros.com/forum/automotive_pictures/62217_Dan_Relays_1.jpg
Friday, July 4th, 2008 AT 12:28 PM
