HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Plymouth
Voyager
Engine Cooling
Cooling Fan
Stays On
1998 Plymouth Voyager Fan keeps running
SUEREZ
MEMBER
1998 PLYMOUTH VOYAGER
6 CYL
FWD
AUTOMATIC
110,000 MILES
Cooling fan to radiator continues to run after engine is turned off. The only way to stop it is to disconnect the battery.
Friday, May 16th, 2008 AT 10:54 AM
OBXAUTOMEDIC
MECHANIC
On most makes and model the radiator fan will run for a few minutes after the vehicle is turned off to help cool the engine.
If that is not the case with yours find the coolant fan relay it is most likely stuck closed and tap on it if the fan shuts off replace the relay.
The relay is located under the hood in the Power Distribution Box.
SPONSORED LINKS
Saturday, May 17th, 2008 AT 7:50 AM
Please
login
or
register
to post a reply.
Related Cooling Fan Stays On Content
1998 Plymouth Voyager Electric Radiator Cooling Fans
After Running Several Errands The Radiator Cooling Fans Did Not Turn Off When I Parked The Van In The Driveway. The Battery Was Completely...
Asked by
Roy Keeney
1 ANSWER
1998
PLYMOUTH VOYAGER
The 2 Electrical Cooling Fans Stay On For Over An Hour...
The 2 Electrical Cooling Fans Stay On For Over An Hour After Turning Off The Van. I Really Need Help With This Problem. Thank You
Asked by
Anonymous
1998
PLYMOUTH VOYAGER
98 Plymouth Voyager Radiator Fans
:( I See Someone Has Already Posted A Similiar Question And Got No Response. Seems That No One Knows The Answer, But I Will Ask Anyway...
Asked by
lwarren01
1998
PLYMOUTH VOYAGER
I Own A 1998 Plymouth Voyager 4 Cyl. 2.4 Van. The...
I Own A 1998 Plymouth Voyager 4 Cyl. 2.4 Van. The Problem Is That When I Shut It Off The 2 Electrical Cooling Fans Stay On For As Much As 2...
Asked by
juvenile
1 ANSWER
1998
PLYMOUTH VOYAGER
Radiator Fan Runs In High Mode All The Time
I Replaced The Relay Under The Hood But The Fan Still Stays On High. The Temp Sensor Is Hard To Get To Under The Coil Or I Would Replace It...
Asked by
semockr
1 ANSWER
1995
PLYMOUTH VOYAGER
VIEW MORE
Online car repair manuals
