1993 Plymouth Voyager Brake pedal wont go down
99,750 MILES • 6 CYL • FWD • AUTOMATIC
JVINSON
Brake pedal is stiff. The ABS pump was replaced under a recall but didnt fix problem so I then replaced the ABS module, still not fixxed. Any input would be a great help. thank you
Jun 18, 2009 at 7:35 AM
CARADIODOC
  • 34,391 POSTS
Do the brakes apply? If not, or if the steering wheel tugs to one side, suspect a constricted front rubber brake hose. Try opening a bleeder screw on a caliper, then watch for brake fluid when someone pushes the pedal. If no fluid comes out or heavy pedal pressure is required, the hose is probably pinched off by rust buildup inside the crimp of the metal bracket holding the middle of the hose. You can open that crimp up a little with a channel lock pliers.
caradiodoc
Jun 19, 2009 at 2:21 PM
