1993 Plymouth Voyager ABS
1993 PLYMOUTH VOYAGER
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
GARSHAR
I recently received a this van because the abs was malfunctioning. I want to diconnect the fuse or relay to the abs but I do not know where it is located. the abs system engages even when I am just slightly braking which makes it hard to drive. My mechanic says to replace abs master cylinder would be very expensive so I am looking for other options.
Feb 2, 2008 at 7:25 AM
BMRFIXIT
  • 19,053 POSTS
[quote:d17f9df20e="garshar"]Brakes problem
1993 Plymouth Voyager 6 cyl Two Wheel Drive Automatic 200000 miles
I recently received a this van because the abs was malfunctioning. I want to diconnect the fuse or relay to the abs but I do not know where it is located. the abs system engages even when I am just slightly braking which makes it hard to drive. My mechanic says to replace abs master cylinder would be very expensive so I am looking for other options.[/quote:d17f9df20e]
check ABS rings on the axles you are looking to check if its cracked
Feb 2, 2008 at 8:21 AM
