1993 Plymouth Grand Voyager 3.3l engine
KROSESC
  • 1993 PLYMOUTH VOYAGER
Does anyone know location of the fan relay swith and ac clutch relay swithes.
Tuesday, August 29th, 2006 AT 9:42 AM
DALE BEAUDET
If you are having problems with your fan only running at 1 or 2 speeds, it's not a relay. It's the resistor block in the firewall on the passenger side of car.
It is pushed into the firewall (not bolted). It has resistors on the back that often go bad. The plug that plugs into it is often in bad shape too. The dealer can get just the plug and pigtail to splice in, and the resistor pack. It took me a long time to locate this problem and repair it![/I]
Wednesday, September 20th, 2006 AT 4:16 PM
