1992 Plymouth Voyager WATER PUMP
1992 PLYMOUTH VOYAGER
168,371 MILES • 6 CYL • FWD • AUTOMATIC
JAMES HOWARD
IS THERE SOME WAY TO STOP A WATER LEAK, WITH OUT CHANGING THE WATER PUMP. THE LEAK IS COMING FROM THE AREA OF THE PUMP. ALSO WHAT IS THE AVERAGE REPLACEMENT TIME FOR THAT TYPE OF PROBLEM.
Jan 19, 2010 at 5:26 AM
BMRFIXIT
  • 19,053 POSTS
What do you have for engine size
I do NOT recommend the use of any sealer as that will cause more problem and it may not work for long
Jan 19, 2010 at 1:01 PM
