1992 Plymouth Voyager Running lights
1992 PLYMOUTH VOYAGER
329,776 MILES • 6 CYL • 2WD • AUTOMATIC
BLUE OX
The running lights won't shut off, unless I disconnect battery. Last summer they stayed on once and when i disconnected the battery they worked till now. However; now they come on as soon as I reconnect the battery cable. Is there a way I can disable them until I can affoed to get them repaired correctly.
Feb 12, 2008 at 5:14 AM
LEGITIMATE007
  • 5,121 POSTS
try the corresponding fuse. but only if that is the only item associated with the fuse. because sometimes several items are on one fuse. but in this case , maybe not
Feb 14, 2008 at 4:52 AM
