1992 Plymouth Voyager pop though intake
182,000 MILES • 6 CYL • FWD • AUTOMATIC
MARK KNAPCHUCK
strong hesitation off line under strong acc. follow by poping tho intake and sometime a little back fire now and then but it does catch itself and go then stop for second and does all over again .
The van has had a tune up and gas system check but has not correct the problem my next idea is the time belt but before a take on that job like to make sure that it does fire right up all time with very little effort of the start even in the cold.
help please Mark K.
Feb 18, 2009 at 5:47 AM
BMRFIXIT
  • 19,053 POSTS
Recheck the tune up and ignition wires
Test the coil
Check fuel pressure and fuel pump
Check timing
Feb 18, 2009 at 5:56 AM
