1992 Plymouth Voyager Parking brake light and ABS light on
150,000 MILES • 6 CYL • AWD • AUTOMATIC
PAPADEE
My ABS light is on and the parking light. The parking brake seems to work fine, it does not appear to be locked. I found a crack in the ring on the passenger side ABS axle and replaced the axel. I still don't have brakes and the lights are still on.
Oct 10, 2008 at 12:43 PM
LEGITIMATE007
  • 5,121 POSTS
if the pedal is hard , or even soft for that matter then your problem is gonna be with the pressure switch. had the same problem with mine.
Oct 12, 2008 at 2:51 PM
WILDFIRE2028
I have the same problem, ABS Light is on and BRAKE light is on and peddle is stiff. Where is the pressure switch located on a 91 Plymouth Grand Voyager 3.3L?
Thanks in advance
Mar 22, 2009 at 1:13 PM
LEGITIMATE007
  • 5,121 POSTS
it is located on the unit, and check to see if the tone rings have any chips on them first
Mar 23, 2009 at 6:10 AM
