1992 Plymouth Voyager location of crankshaft position senso
175,000 MILES • 6 CYL • AWD • AUTOMATIC
FIFTY6WILD
I have a chiltons manual and the diagram does me no good. I can't find it. Where on the transaxle housing is the sensor. Do I need to take the drivers side front wheel off to see/get at it?
May 13, 2010 at 1:03 AM
2CARPRO JACK
  • 11,533 POSTS
Its a bear to find.It is located on top of the bellhousing, under the exhaust croos over, towards the firewall.
https://images.2carpros.com/forum/automotive_pictures/1639_Graphic_7.jpg
May 13, 2010 at 1:18 AM
JALOPYPAPA
  • 467 POSTS
You pretty much have to get under the car, behind the crossmember, and look forward at the back of the bellhousing to see it.
May 17, 2010 at 10:32 PM
FIFTY6WILD
That's exactly what I did, and even then it was a pain to get at. It was harder to find because the wires were sheared off right at the sensor. I found the harness it plugs into before I found the sensor. It was a big job for one little bolt, but it's done and running fine again. Thanks for your help
May 18, 2010 at 1:04 AM
2CARPRO JACK
  • 11,533 POSTS
Glad to hear you are back up and running.. thanks for using 2Carpros.com
May 18, 2010 at 1:09 AM
