1992 Plymouth Voyager flashers
1992 PLYMOUTH VOYAGER
200,000 MILES • 6 CYL • FWD • AUTOMATIC
JOESPINUCH
  • 9 POSTS
was doing dome work under dash and have lost turn signals. 4 ways work but no left or right. where are the flasher modules located ?
Aug 13, 2010 at 9:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Your vehicle has a combination flasher relay for both the hazards and the signals, if the hazards work then the flasher is good. Most like the fuse has blown to the signals, it is fuse #7 (20 amp) in the fuse panel located under the parking brake handle.
Aug 13, 2010 at 10:06 AM
JOESPINUCH
  • 9 POSTS
fuse is good
Aug 13, 2010 at 12:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check the wiring to the signal switch then, may have disconnected it by accident.
Aug 13, 2010 at 12:57 PM
JOESPINUCH
  • 9 POSTS
would I be correct : power goes from block to-- flasher to turn sig sw as well as power block to flasher to hazard sw-- and then each path goes to lamp circ's? would you have color codes and location of flasher?
Aug 13, 2010 at 1:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sure but want to make sure is this a Voyager or a Grand Voyager?
Aug 13, 2010 at 1:38 PM
JOESPINUCH
  • 9 POSTS
ply voyager le 3.3 engine dang thing has everything "cept butt warmers!
Aug 13, 2010 at 1:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
ok i found a diagram but its so large its hard to read in the forum. what is your email and i can send it that way, you can view it larger and better that way i would believe..
Aug 13, 2010 at 1:57 PM
JOESPINUCH
  • 9 POSTS
joespinuch@gmail.com
Aug 13, 2010 at 2:03 PM
