1992 Plymouth Voyager Engine will not turn over
JACKJSP
  • 1992 PLYMOUTH VOYAGER
Engine Mechanical problem
1992 Plymouth Voyager Two Wheel Drive Automatic
My 1992 Plymouth Voyager ran perfectly fine (As good as it runs anyway) and as the day progressed the van was driven to the end of the street where it decided it was going to stop trying to turn over. The dash, head, and all other lights work so I know it's not the battery. The starter worked fine this morning so I don't think it could just stop working like that. No cab fuses blown. Should I try to jump it? Answer hoped for ASAP.
Friday, November 21st, 2008 AT 3:10 PM
BMRFIXIT
  • 19,053 POSTS
Check oil level
Jump will be ok
if start with a jump suspect bad alternator
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Saturday, November 22nd, 2008 AT 6:55 AM
