1992 Plymouth Voyager electrical radiator cooling fan motor
173,000 MILES • 6 CYL • FWD • AUTOMATIC
STUDENTTX55
The electrical motor for the radiator cooling fan has locked up and started smoking. Do I need to replace this electrical motor, or the entire fan assembly including the shroud, the fan and the electrical motor?
Jul 4, 2008 at 6:44 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0f855ed498="studenttx55"]Engine Cooling problem
1992 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 173000 miles
The electrical motor for the radiator cooling fan has locked up and started smoking. Do I need to replace this electrical motor, or the entire fan assembly including the shroud, the fan and the electrical motor?[/quote:0f855ed498]
You can replace just the Motor.
Jul 7, 2008 at 2:20 PM
