I have a 1992 plymouth Grand voyager that overheated recently and blew th radiator. I replaced the radiator, filled it up with fluid and got it going again. However the fan will not run. I hooked it up directly to the battery and it seems to work fine. Someone said it may be a relay or module of some kind. Where would this part be found on the car? Do you have any other ideas to try? Thanks.
Jun 6, 2010 at 4:38 AM
