1992 Plymouth Voyager ABS brake fluid pump
210,000 MILES • 6 CYL • FWD • AUTOMATIC
REPAIRMAN1284
I have a 1992 Plymouth Grand Voyager with ABS and 3.3L v6 engine. The electric power brake pump activates for a few seconds, then stops, then about 5 seconds later it activates again, and again and never stops cycling. There is no fluid loss and the brakes still work. It acts as if the fluid is passing back through an internal check valve and bleeding off the pressure. Do you suspect the problem is in the pump unit that is mounted on the transmission or the master cylinder unit above? Thanks so much. Any help or references appreciated. Thanks, Gene
Aug 12, 2008 at 9:49 AM
MERLIN2021
  • 17,250 POSTS
First step is scan for codes with a scan tool that reads Chrysler ABS codes, this will pinpoint the bad parts or circuits to check for shorts.
Aug 12, 2008 at 9:59 AM
