1991 Plymouth Voyager Transmission
1991 PLYMOUTH VOYAGER
109,571 MILES • 6 CYL • FWD • MANUAL
STOBERM
I have a 1991 Voyager and I have a vibration in the front end only when accelerating, when I am coasting the vibration goes away. It only happens when I load up the van with an extra passenger. When I am alone it does not vibrate. I have replaced both motor mounts and the transmission mount. Installed new front struts and rear shocks, replaced both cv chafts. I still have the vibration it is in the body of the van I do not feel it in the steering wheel. I have checked both lower ball joints and they are tight. I checked the steering rack and there is no play in it, or the outer tie rods. The tires were balanced and the front end was aligned. I read the haynes manual and it said to adjust the motor so I adjusted it to the drivers side and to the passenger side it did not help. Do you have any ideas I am not sure where to go from here.
Jan 11, 2009 at 3:04 AM
  • 110,240 POSTS
Hi:
The fact that you feel it in the body of the car and not the steering makes me believe the problem is in the rear and not the front. Have you checked rear wheel bearings for condition and tightness?
Jan 11, 2009 at 3:35 AM
