1991 Plymouth Voyager Starting issues
227,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRBUTT2921
I turn the key and can hear the fuel pump. The engine turns like it wants to start but no ignition. I do this usually about 3 times or so and then it will start. Sometimes after the engine has run for a while it will start right up if it hasn't been off for too long. Usualy when the engine has been off or is cold it will take 3 to 4 times before it starts. Any suggestions on what I can do to fix this problem would be greatly appreciated.
Oct 14, 2010 at 8:30 AM
  • 75,988 POSTS
Start by checking out the fuel system-Possibilities here could be fuel pump relay,low fuel pressure due to fuel filter and fuel pump-
Oct 14, 2010 at 6:51 PM
