1991 Plymouth Voyager starter
150 MILES • 6 CYL • 2WD • AUTOMATIC
JTODD2891
the starter is smoking and turning slow
whats the matter?
May 14, 2009 at 11:41 AM
  • 110,248 POSTS
It sounds like something has shorted out in it and it is drawing too many amps. I would remove it and have it bench tested at a parts store. Most will do it for free. That way you will know if that is what is causing the problem. It could cause a fire it I am correct.
NOTE:
THey are not too hard to replace. If you need help, let me know.
May 25, 2009 at 1:26 PM
