1991 Plymouth Voyager cluster
PANCHO ROD
  • 1991 PLYMOUTH VOYAGER
  • 6 CYL
  • 161,000 MILES
Themperature, mileage and fuel gauges are not working. Fuses and sensors are working. Is there a problem with the computer? I appreciate your help helping me fix this.
Monday, October 18th, 2010 AT 2:19 PM
JDL
  • 16,098 POSTS
Did you use a voltage tester at the applicable fuse. Even if the fuse is good, if no voltage, the circuit is dead. The cluster itself may have a problem? Could be an issues with sending unit?
Fuse 15-- 10 amp should be for the gages, goes hot when you turn on the key.
https://www.2carpros.com/forum/automotive_pictures/170934_voyager_fuse_box_1.jpg
Monday, October 18th, 2010 AT 3:44 PM
