1991 Plymouth Voyager
TONYNC1968
Drive Train Axles Bearings problem
1991 Plymouth Voyager Two Wheel Drive Automatic
i have replaced trans mount,front center mount,and bracket,and ofcourse,the left side axle assy.it seems that every time i go over a large bump,or turn real sharp,it breaks the left side axle,its almost like the axles to short,because it breaks from the axle shaft,to the input shaft to the tranny,any help?
Apr 16, 2008 at 11:46 AM
SERVICE WRITER
  • 9,123 POSTS
You have to loosen the mounts, center the engine by using measurements from the axleshaft.
https://images.2carpros.com/forum/automotive_pictures/30961_shaft1_2.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_shaft2_2.jpg
Then torque them back down.
Apr 16, 2008 at 1:43 PM
