automatically shifts into second gear and remain there
1990 PLYMOUTH VOYAGER
180,000 MILES • 6 CYL • FWD • AUTOMATIC
CHARLIE
transmission automatically shifts into second gear and remain there regardless of the forward gear selected.
Dec 29, 2007 at 5:45 AM
SQM
  • 6,383 POSTS
Shifting issue can be triggered by several different factors. It is always a good idea to make sure the transmission fluid is at proper level and in good condition anytime there is shifting issues.
This can also be due to faulty shift solenoid; a weak transmission oil pump can contribute to this as there won't be sufficient fluid pressure for the transmission to shift properly.
Another possibility is a clogged transmission filter. This can prevent proper flow of fluid and will create this type of shifting issue. So, changing the fluid and filter is a good first step.
Here is a helpful guide to transmission fluid change:
Oct 29, 2021 at 5:51 AM
