1990 Plymouth Voyager tie rod ends
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHERRY4412
how do you replace inner tie rod end.
Sep 26, 2008 at 6:11 AM
JALOPYPAPA
  • 467 POSTS
Remove the outer tie rod end from the steering knuckle. Unclamp the rack boot, pull it outboard. Get a crescent wrench and turn the inner tie rod end off the rack. Make sure the vent tube is in its hole when replacing the boot.
Oct 3, 2008 at 5:24 AM
