Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Plymouth
Voyager
Steering
Tie Rod End
Replace/Remove
1990 Plymouth Voyager tie rod ends
1990 PLYMOUTH VOYAGER
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHERRY4412
MEMBER
1 POST
how do you replace inner tie rod end.
Sep 26, 2008 at 6:11 AM
JALOPYPAPA
MEMBER
Remove the outer tie rod end from the steering knuckle. Unclamp the rack boot, pull it outboard. Get a crescent wrench and turn the inner tie rod end off the rack. Make sure the vent tube is in its hole when replacing the boot.
Oct 3, 2008 at 5:24 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
