1990 Plymouth Voyager no gage activity when ignition key tu
183,000 MILES • 6 CYL • FWD • AUTOMATIC
EPONDER
motor turns over, altanator, battery, test good. turn on ignition switch gages don't move. No check engine or any other sign of normal gage activity. First started when driving down road and motor would cut out. Then almost as quick motor would run again. Now at point where motor tuns over but will not start and gages SHOW NO MOVEMENT LIKE NOT GETTING A SIGNAL.
Oct 23, 2008 at 1:59 PM
  • 110,248 POSTS
Hi:
It sounds like a ground problem. Have you checked the basics like battery terminals, battery ground at engine... If they are all good, you may want to have the BCM checked.
Let me know if you have any other questions.
Nov 5, 2008 at 5:36 AM
