1990 Plymouth Voyager head light switch
C.LANDRY
  • 6 POSTS
1990 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
Does anyone their know how to replace a headlight switch on a grand votager?
Jul 26, 2010 at 1:03 AM
CARADIODOC
  • 34,413 POSTS
Hi C.Landry. Welcome to the forum. The trim bezel in front of the switches is held on with velcro. Pull it off to expose four mounting screws. With those screws removed, pull the plate out. A threaded nut holds the headlight switch to that plate. There's a spring-loaded metal button on top of the switch. Press it down, then pull the knob and shaft out of the switch. Just push the shaft back into the new switch and it will latch in place.
caradiodoc
Jul 26, 2010 at 7:07 AM
