The number one injector is for the number one cylinder.
Jul 19, 2009 at 3:48 AM
GARYGARRETT
MEMBER
[quote:0f1f7dab78="garygarrett"]Engine Mechanical problem
1990 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 123456 miles
location on number 1 fuel injector[/quote:0f1f7dab78]is it the same as fire order
Jul 19, 2009 at 5:16 AM
GARYGARRETT
MEMBER
thanks!!!!
Jul 19, 2009 at 5:23 AM
JDL
✓Experienced Mechanic
I was just trying to show location of number 1 cylinder. the number 1 injector should be close to the number 1 cylinder. You may need to remove the air-plenum to get at the injectors?
