1989 Plymouth Voyager Will not start
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRBRIAN43
I tried to start the van,but it only cranks over.I popped the hood and found a wire and I don't know where it goes.
Jan 31, 2008 at 12:17 PM
BLACKOP555
  • 10,386 POSTS
can you get a picture of it? without that i cannot tell you what it is.
Jan 31, 2008 at 12:43 PM
BMRFIXIT
  • 19,053 POSTS
[quote:4b30345c54="mrbrian43"]Other Category problem
1989 Plymouth Voyager 6 cyl Two Wheel Drive Automatic 150000 miles
I tried to start the van,but it only cranks over.I popped the hood and found a wire and I don't know where it goes.[/quote:4b30345c54]
did you check for fuel or spark
listen at the tank with key 1st on for the fuel pump
posibility ---fuses--relays--crank sensor --fuel pump
in that order
Jan 31, 2008 at 12:46 PM
