1989 Plymouth Voyager water in oil
MYOMY
Engine Cooling problem
1989 Plymouth Voyager 4 cyl Front Wheel Drive Automatic 270k miles
i have replaced the raidiator and cap and thermistat. still loosing water and getting more water in oil. then i replaced head gasket. still getting some water in the oil but not going threw as much water.
Mar 4, 2009 at 10:56 AM
  • 31,937 POSTS
Hi there,
Pressure test the cooling system to locate any external coolant leaks, did you have the head crack tested and machined flat? did you make sure that all old head gasket was removed from the block?
mark (mhpautos)
Mar 4, 2009 at 11:09 AM
MYOMY
i did not have the head tested or machined. i am sure i got all the old gasket cleaned out.
Mar 4, 2009 at 11:34 AM
  • 31,937 POSTS
Hi there, you should always get the head tested and re machined as they always twist and warp, you may also have a crack in the head, you can never presume that it is ok, just re flush the coo ant and re fill maybe its just old oil still in the system, but i feel that your head is still the problem.
mark (mhpautos)
Mar 4, 2009 at 11:41 AM
