1989 Plymouth Voyager Maintenance Required light..code 17
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
89VAN
The maintenance required light came onfor the first time in almost 20 years. I checked for codes, got 17. (coolant temp too low) I put a new thermostat in last summer. I disconnected the battery to remove the code but the light stays on. Is there any way to turn the light off without paying $65 for a dealer scan?
Feb 4, 2009 at 7:12 AM
JDL
  • 16,098 POSTS
Is it extremely cold in your area? You might check the cts circuits. If the lite came on because of a problem, it won't stay off till the problem is fixed.
Feb 4, 2009 at 7:32 AM
