Your loss of power at times could be loss of fuel pressure, possable restriction. The other item which I have found to be a map sensor issue, remove it and check for possable oil intrusion. Also check any vaccume lines for resticion or cracking. If map sensor does have a noticeable amount of oil from the vaccume connection I would reccomend replacement
and check your pcv system for proper operation. Are there any engine light when this acts up?What is intake vaccume readings? If vac. Is low you may have a cat. Convertor issue.
Friday, February 6th, 2009 AT 2:55 PM
