1988 Plymouth Voyager head gasket repair
1988 PLYMOUTH VOYAGER
88,000 MILES • 6 CYL • FWD • AUTOMATIC
RICHEYB
I have a busted head gasket--can I repair that without removing the engine?
Simple question
Oct 10, 2010 at 12:48 PM
We appreciate your donation and were sorry we didn't response rapidly-
You don't have to remove the engine-all you got to do is remove the affected cylinder head from the top where that gasket is-its gonna be tedious but can be done
Oct 10, 2010 at 12:54 PM
THIS IS MIKE
  • 686 POSTS
Hi B Richey, richeyb,
We appreciate every donation and do our best to help everyone we can. We answered your question within 4 hours? You donated using this
member name B Richey
We sent you an email to the email address you signed up with. If you look at your profile you will see you input a different email address than the one you signed up with on this user name and why you didn't receive our notification "richeyb"
Here is the direct link:
https://www.2carpros.com/forum/1988-plymouth-voyager-replacing-head-gasket-vp1006295.html?highlight=#1006295
Posted at Fri Oct 01, 2010 3:05 pm
By merlin2021, Certified ASE Technician
"Richey, it can be done that way, or if you have a lift or can jack and stand the body high enough, you can drop the cradle and remove the motor and tranny, with the axles and all... remove the three nuts at the top of the struts, unplug harnesses, and lower it all with a good floor jack. The exhaust at the back side will be your hardest challenge.
_________________
Oct 10, 2010 at 1:28 PM
