1988 Plymouth Voyager doesnt start
156,000 MILES • 4 CYL • 2WD • AUTOMATIC
SSUTTLE13
I have spark, I have fuel pumping to the carb, If I dump fuel down the throat it fires till all is burnt. It seems as the carb is being switched off. This is a throttle body fuel system. I just replaced the spark wires ,distributer cap and rotor. like I said I have spark
Mar 24, 2008 at 1:38 PM
BMRFIXIT
  • 19,053 POSTS
check fuel pressure and fuel pump
check fuses and tps volts
Mar 24, 2008 at 2:00 PM
