1987 Plymouth Voyager Wont start
48,000 MILES • 6 CYL • FWD • AUTOMATIC
COREYB56
87 Voyager has sat 4 years turns over but won't start put new gas and Seafoam in. Where do I go from here?
May 27, 2009 at 4:31 AM
JDL
  • 16,098 POSTS
Hello, I'd probably give it a tune-up, check all the fluids, change the oil and filter, before I even cranked it.
Have you done any basic testing? Have a helper crank it while you check for spark at the plugs. Plenty of spark, check fuel pressure. Can you check for troublecodes? You turn the key just till dash lites come on, no further, cycle the key on--off, on--off, on then the check engine lite starts flashing, you count the flashes to get the codes.
May 27, 2009 at 5:26 AM
