1984 Plymouth Voyager not starting
ERIK JONES
Electrical problem
1984 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
van does not start everytime,,turn key and hear clicking noise after trying two or three times does start...battery new,,starter relay new,,battery cables are ok... if you have any suggestions on what may be the problem would love to know...
thanks Erik
May 1, 2010 at 12:03 AM
  • 75,988 POSTS
Try engaging the starter thru the starter relay if it works a few times with no problem check and test the transmission range switch and ignition switch
May 1, 2010 at 7:43 AM
