1978 Plymouth Volare Brake problem
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
NZSTRANDBERG
i actually have a 1978 dodge aspen but since these 2 are essentially the same car thats what i put it under. when i push the brake pedal it doesnt return fully and leaves the stoplight engaged. i have to pull it up with my left foot. the guy i bought it from suggested the brake booster. what should i look at?
Feb 15, 2009 at 10:18 AM
  • 75,988 POSTS
Try adjusting the brake booster pushrod, check the return spring could be sprung and check the brake switch adjustment
Feb 15, 2009 at 10:29 AM
