1991 Plymouth Sundance left turn and brake light
39,850 MILES • 4 CYL • FWD • AUTOMATIC
MILLER_GD
my left rear brake light or turn signal doesn't work. I can manually use the turn signal and it works in the front and sides, but not the back. I tried changing the bulb and put it a new socket and it still doesn't work. any help would be appreciated.
Feb 21, 2009 at 5:41 AM
  • 110,246 POSTS
If you replaced the socket, did you check to see if you were getting power to the wiring?
Mar 22, 2009 at 6:19 AM
