1989 Plymouth Sundance vaccum hoses
1989 PLYMOUTH SUNDANCE
70,000 MILES • 4 CYL • FWD • AUTOMATIC
HARRISQUON
Hi there,
I'm replacing my M.A.P sensor vaccum hose.
My question is "Do the hose have to be the same size as the original?
Jun 14, 2010 at 3:32 AM
BMRFIXIT
  • 19,053 POSTS
Exactly the same no
but using bigger, that may cause a leak is no good and very small may cause a restriction
so if its within reason and no leaks it should be OK
check vacuum source in the manifold if restricted
Jun 14, 2010 at 6:13 AM
