Electrical problem
1989 Plymouth Sundance 4 cyl Manual 150000 miles
My brake lights are coming on dim according to an observer and my turn signals are blinking very slow or not at all. Is this just a problem with needing to replace a flasher switch/relay? If so where is it located? Also, are these two problems related? My serpentine belt might be a little loose....could that cause the dim brake lights and also slow flashers?
Aug 11, 2009 at 3:22 PM
