1989 Plymouth Sundance oil light
CHEVYMAN3.8REDNECK
Engine Mechanical problem
1989 Plymouth Sundance 4 cyl Front Wheel Drive Automatic N/A miles
my girlfriend just got a 89 plymouth sundance real cheap but needs some work and i was wondering what would make the oil light come on even after the oil sender was changed and the car seems like it idles fine im just hopin its not the oil pump and there is a mess of wires that someone took the wrapping off of and i was wondering if that has anything to do with it because i think one or some of them go to the sender.? I would greatly appreciate this question be responded to asap because i cannot pay for one right now.
Nov 1, 2009 at 10:00 AM
  • 75,988 POSTS
Use a mechanical gauge and read the pressure if its normal you have replaced the oil pressure switch already- abnormal could mean oil pump and engine bearings
Nov 1, 2009 at 10:09 AM
