Hi, glad to have found you guys....I am trying to fix this car and I am going out of my mind....the car starts and then stalls immediatley. I disconnect the map sensor and it idles very low and stumbles, when I plug in the map sensor it sucks hard through the throttle body and then stalls. it is getting fuel and spark and timing belt is tight the vacume is at about 14 lbs. when the car died it was running fine shut it off and a few hours later it would not start it blew a few fire balls out of the throttle body and when you pump the s**t out of it it will run for a few seconds or just bog out...changed computer,tbs,map,idle control,injector,pressure regulator,pick up coil,cap,rotor and plug wires.......please if anyone can help I would really appreciate it I am going out of my mind (no codes to indicate a problem) thank you.
Richy
Richy
Jan 22, 2009 at 2:10 AM
