1969 Plymouth Roadrunner load on electrical system vehicle
RAUL MATA
Electrical problem
1969 Plymouth Roadrunner V8 Two Wheel Drive Automatic
I have a 69 R/R 440 with approx. 500hp not a race car just a weekend street car. I have new electrical wiring in the engine compartment. I have no problem running my car during the day, but once I need to turn on the lights the vehicle shuts down. The vehicle is not able to hold the load of the lights. I purchased a new battery optium with pleanty of juice, should I be looking at the alternator possibly. Any advise will be greatly appreciated.
Thank You
R. Mata
Jul 8, 2009 at 3:42 AM
BUDDYCRAIGG
  • 2,262 POSTS
if you still have the 1969 alternator on it, you can do a full field test while you have a meter hooked to the battery and the lights on.
that would give you a good idea if the alternator is too weak.
or if you still have a points style regulator, it could need to be cleaned and adjusted.
Jul 8, 2009 at 7:38 AM
