1969 Plymouth Roadrunner
REDMANN
Heater problem
1969 Plymouth Roadrunner V8
On the fire wall i have a leak right behind the intake manifold. The car has factory air and it all works. It looks like there is a hose missing ? possible heater core line ? should there be a hose on this or plugged ?
Oct 11, 2009 at 2:51 AM
HMAC300
  • 48,601 POSTS
there shold be 2 heater hoses for the heater. One going to it and one returning to the engine. They should connect near teh front of the engine. you might have a leaky heater core. If you feel carpeting wet on the passenger or driver side then it is leaking antifreeze. Time to fix it.
Nov 13, 2009 at 1:07 AM
