1988 Plymouth Reliant Radiator water is milky white color
1988 PLYMOUTH RELIANT
206,237 MILES • 4 CYL • FWD • AUTOMATIC
RELIANTGIRL46
I have a 1988 Plymouth Reliant. The radiator water looks like a milk color. What would cause it to turn that color? I do have to put water in it pretty often and I don't think I should have to do that. I haven't noticed any leaks.
Feb 19, 2009 at 3:02 AM
KAROW1972
milky coolant means you have oil in it. your oil is probably the same color. since you havent noticed any leaks you probably have a blown head gasket. take compression readings from your cylinders and one is going to be considerable amount lower.
good luck
Feb 20, 2009 at 11:04 AM
