1988 Plymouth Reliant Car wont start regardless of no known
SAMMYW308
Engine Performance problem
1988 Plymouth Reliant 4 cyl Front Wheel Drive Automatic ???? miles
I bought the Reliant about a month ago.. The guy I bought it from said it hadn't been driven in a while because of a family problem.( I personally think its a load of bs, but oh well) We ran out the stale gas in the tank and started running it on unleaded, it ran for about a month even though it would idle high and you would have to sometimes drive two footed or when you came to a red light put it into nuetral to keep it from dying out. Now it wont start at all! It has a brand new radiator, distributor, carb, fuel pump, and fuel filter.It tries really really hard to start but wont. I got it to start yesterday by unplugging the MAP sensor, but it died immediatly after starting. I checked the computer codes there were none. The only ones I got were 12 and 55, which mean that the battery had been disconnected in the past 50-100 ingitions and the 55 meaning the end of the test. What could be wrong with this car to make it not start?
Jul 20, 2010 at 1:13 PM
KEVIN HOFFMAN
it is most likley the map sensor , I used to carry one in the tow truck with me, the test was to disconnect it and it will idle only,your high idle sounds like another problem like a loose vacum hose or vac leak ,this could mess up the sensor test . good luck
Jul 12, 2012 at 6:38 PM
