[quote:b191a7a7e7="delyle"]Engine Performance problem
1987 Plymouth Reliant 4 cyl Front Wheel Drive Automatic 75000 miles
On the 1987 Reliant, where is the EGR valve located? I've got code 34 that states the EGR solonioid circuit is open. Does this pertaiin to the EGR valve itself or an electronic component somewhere?
Thanks,
David[/quote:b191a7a7e7]
Thanks for the reply but there is nothing on the right front shock tower - at least nothing that looks as complicated as what you diagramed. By right I assume you mean the passenger side.
I was able to locate the EGR valve and it's on the back side as the intake is located on the back side of the motor next to the firewall.
Any other place I should look for this electronic contraption?
Thanks again,
David
Mar 25, 2008 at 5:30 AM
