i have a 1994 plymouth 3.3 V6
and have several problems
my starter wont crank
i found out that i also have a cooling leak
and when i engage a gear it seems like if its on neutral only the parking gear work's
thank's for any help
yvan.
Check that the automatic transmission fluid is full. If it is full and there is still no drive, look for a check engine light or sensor fault; otherwise suspect the valve body or an internal transmission problem. For the no-crank, have a helper turn the key to start and check for 12 volts on the small wire at the starter.
The owner of a 1994 Plymouth 3.3 V6 reports that the starter will not crank, there is a coolant leak, and selecting a gear feels like neutral while only park works. The expert advises confirming the transmission fluid level, checking for a check engine light or sensor issue, and considering a valve body or internal transmission fault if the fluid is full. For the starter, check for 12 volts at the small starter wire while the key is held in start.
