plymouth sundance losing accelleration
PLYMOUTH
WENDYGRICE
My daughter has been experiencing a problem with her 1994 Plymouth Sundance. It has approximately 100,000 miles. She says as she tries to accellerate, it will suddenly slow down to 30 mph or less, and will not return to speed. Sometimes the car dies and then will not accellerate. If she presses on the gas, the car does something she calls "bucking". We took it to our mechanic and he drove it and could find nothing wrong, so he tuned it up. Two weeks later it was doing the same thing. We took it to our friends trusted mechanic. He also drove it, found nothing wrong and tuned it up. Now, we have spend close to $500. and it is still doing the same thing. This morning it lost power on the freeway and dropped to 35 mph. We're out of money for this little car. Any ideas?
Apr 28, 2007 at 4:38 AM
2CARPRO JACK
  • 11,533 POSTS
Id do a fuel volume/pressure test. Could be a weak pump or one that is going out on you. Any check engine light? if so have it scanned and get back to us with the code/codes
Apr 29, 2007 at 1:28 AM
WENDYGRICE
Thanks for the tip! I'll keep you posted. Oh, and the check engine light isn't on.
Apr 29, 2007 at 1:37 PM
