My new dual exhaust has white smoke coming out of one side
PLYMOUTH
65 PLYMOUTH
I have just recently had a new dual exhaust put on my 65 Plymouth Belvedere. As long as I have known it has always blown some smoke, but now that it has a dual exhaust the smoke is only coming out of the left side. Roughly the same amount of pressure comes out of both sides, but the left side just blows a fairy wet, white smoke. Can anyone tell me what is causing this and how I can fix it. Thank you very much, I greatly appreciate it.
May 4, 2006 at 10:45 AM
VANDRAGON
  • 298 POSTS
sounds like you have a worn valve guide or cracked oil ring. even a drain back hole on the left head could be clogged.
May 6, 2006 at 9:43 AM
K.C.
You didn't say if you need to put water in it occaisionaly or not(wet smoke?), if you do, it may be a head gasket. Do a compression check. Good luck. K.C.
May 7, 2006 at 2:24 PM
